Hi,
Just wanted some feedback of the changed frequency responses in my ht room. I used the RS SPL meter, as well as the BFD DSP1124P. The blue line is what I started with, the pink is what I ended up with after some work. I have the Denon 3805 with the sub crossover set at 80hz, speakers on small, my M&K sub at about 1/3 to 1/2 volume, with the phase on +, the crossover on the sub all the way up to 150hz or whatever is was.
I guess the question is, do my settings look acceptable to the pro's here? I won't be able to really crank it up and listen to it until tomorrow since the kiddy's are asleep now. But at lower volumes, it sounds better then it did.
Tomorrow I am also planning on tuning the rear sub.
The M&K is up front next to my front left main. It is in cabinetry and I've been working hard at trying to get it to sound good. I've insulated the death out of the cabinet and the sub fits tight (sub-amp is on outside of cab).
I was struggling trying to flatten the FR until I read that I should have the crossover on the sub all of the way up. I was under the impression that it should be on 80hz to match the receivers crossover. Fixed that and now it was easier to tune. I just hope it is in the ballpark.
[/IMG]
Thanks for any feedback!
Mike
