Subwoofer A<>B switch
jagdriver
I bought a portable Boston Acoustics subwoofer for use in the master bedroom and on the patio. I plan to physically move it between these two locations.
I'm putting in a main run from my system up to the master bedroom, where I'd like to put an A<>B switch. The A position would run the BA sub when it's in the bedroom, the B position for the patio.
Do I even need a switch? Would a simple Y adapter suffice, knowing that one end will always be without any resistance (i.e., the sub will be connected to the other run)? If I do need a switch, what do you recommend?
Midcow2
Midcow2
Use Y adapter
I would use the Y-adapter.
The sub output is pre-out level and you can connect two subs at once. If you eventually get a second sub you could leave both connected.
An A/B switch in this case is not necessary and would just be extra hassle setting to A or B position.
