Subwoofer $150 price range...
DarkNessBear
...That would use Coaxial connection?
And is coaxial connection good? I have a HTR-5935 AV reciever.
I have my subwoofer as of now plugged in with Banana Plugs and I can barely hear it... Even when I sit right next to it I can't hear crap. And I have my Reciever set to SWFR+10 BASS+10 .
And is a bad idea to have your front left and right speakers to output bass as well?
mazersteven
mazersteven
How large is your room? Any large openings to other areas of the house?
mazersteven
mazersteven
It's my bedroom. And it's about
MY ROOM SIZE:
158x130inches
The carpet is a bit thick, and one wall is mostly windows, thats about it.
So I think I am gonna get the:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-635
Can it be connected via Coaxial?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023601&p_id=619&seq=1&format=1#largeimage
Thanks!
:D
Sounds like you have everything under control. Let us know how the new sub performs for you. :D
Check shipping with Amazon also.
http://www.amazon.com/Dayton-SUB-120-Watt-Powered-Subwoofer/dp/B000C9NV78/ref=sr_1_2?ie=UTF8&s=electronics&qid=1200780860&sr=1-2
DarkNessBear
Hmm, the bic has free 1 day shipping though.
Ergh.
mojo_13
I have not heard either one of those BIC's but for 239 you can get the BIC H-100 shipped off of ebay from the authorized dealer. I have this sub and it gets pretty low and can get loud. If you want to be on a lower budget the velo vx-10 is a nice sub. Those daytons I have heard are a good sub for the money but I havent had any experience with them. Also I heard that the 10" is a less boomy but again I have no experience with them so a little research could go a long way on that. Hope this helps.
