Subs - JBL, Yamaha and which Dayton...Help
K
kera
I am looking for a $100 - $200 range sub to go with my Athena point 5( I plan to get a pair of Athena AS-B1 to replace the mains later). My use will be like 70% movie and rest music.
Last week I got a chance to listen to the 10” JBL E150PBE, 12 “JBL E250P and the $99 Yamaha SW215 at BB(all playing the same Jazz). I was expecting a lot from the JBLs. Surprisingly, I found the Yamaha much better in terms of producing tight bass as compared to the boomy JBLs. The 12” driver JBL was more boomy than the 10” driver one.
I am neither experienced nor an expert to distinguish between the ‘GOOD’ sound and ‘BAD’ sound. All I did was just finding out what I liked. So far, I am used to only an 8” Sony sub that came with my old HT package. So, both of JBLs and Yamaha sounded better than what I heard before.
However, I am planning to buy neither the JBL nor the Yamaha. I am closing in on the Daytons. There is no way I can audition one of them. So, I have to depend on your input. Are the Daytons boomy like the JBLs or can they more like the Yamaha? Which will be more suitable for my room of size 20x12 feet in the basement? (I don’t usually play them very loud)
Dayton seems to have good reviews. That's why I am inclined towards them..Plus they have a sale now..
Please help decide
Thanks
Kera
Athena Point 5
HK AVR 235..
AS B1s later..
Sheep
Sheep
Please help decide
Thanks
Kera
Athena Point 5
HK AVR 235..
AS B1s later..
For your size room, your going to want a fairly powerful subwoofer. I would recommend the 12inch front ported dayton one if its in your budget.
SheepStar
Sheep
Sheep
Thanks Sheep. Were you referring to this one ?
http://www.*****************/pe/showdetl.cfm?&DID=7&Partnumber=300-634
try it apain but make it part (no s) express.com they blocked the other one due to a member working for them and pushing product in the forums.
SheepStar
Edit: also, to quote what I said, just hit the quote button and it does what I have just done here! :)
K
kera
oops..link problem - Dayton 12
I don't know how to paste the link..
Sheep, were you referring to the DAYTON 12" 150 WATT POWERED SUBWOOFER
Thanks
Sheep
Sheep
Thanks
Yes I believe that is the one. I could only find the 10inch version, their website is hard to navigate.
Hope this helps,
SheepStar
K
kera
Dayton boomy like JBL ?
Thanks for the help. I am still not sure if the Dayton is primarily boomy like the JBL...
