I have already calculated the modes for each dimension just as Dr. Toole instructed. But, what do I do from there? How do I calculate the wavelengths for said modes? I already have (2) of the SB12-NSD's here and (2) more are on their way as we speak. Tomorrow, I will order a CSL UMiK 1 and already have REW downloaded. So, there will be about 9-12 axial modes that I need to be concerned about right? That is, 3-4 axial modes for each dimensions, no?
Cheers,
Phil
1130 (speed of sound - feet per second) divided by the frequency (hz) gives you wavelength.
example: 1130fps/20hz = 56.5 ft diameter
Recommend listing your calculations in the format that Floyd did, that way you can more easily see which frequencies suffer from multiple modes. Due to rooms having windows/doors etc, the walls can flex more easily, so measured modes are typically lower in frequency than predicted.
The number of axial modes in a room depends on the room. Mine for example is an open living room, so I've got a lot of work to do still and of course I'm sick today, so my custom sub isn't quite finished. Just running dual SVS PC12s currently.
Your measurements should yield a steady rise in bass from 20 hz, a smooth horizontal line across from there, until around 15khz +/- it tapers off as a result of propagation loss - wavelengths at those frequencies are measured in millimeters, and as most listening is done in the far field (beyond 2-3m) they run out of energy more quickly.
If you are doing all of this, Do NOT run audyssey or any room correction. If you already have, you will need to reset your receiver/preamp. An omni mic in an unknown room, with unknown speakers cannot possibly know what the speaker sent out, and how the room influenced it. (Floyd has written about this in multiple places) This is the controversial part as so many have been bought and sold by the idea of auto setup. The truth is, a good loudspeaker (smooth on axis, off axis, directivity) will sound fine all on it's own just from listening and adjusting the distance from the wall behind, as well as adjusting the distance between and toe in. The trick is getting the bass right below transition frequency of the room (typically 200 hz) and that is why you are doing all of this math. The room is in control, so if you want the best sound, you can mathematically predict ideal locations for subs.
A subwoofer is a pressure source, so you can therefore measure where you have pressure minimums/maximums all around the room (apply a grid 3ft /1m for starters) and that will give you a clear picture of how all these standing waves are influencing your listening position. The subs can be positioned in pressure minimums to boost pressure and vice versa.
Oh, and measure 20hz - 20khz sweep around 80 dB. I've seen people confusing room measurements with max output tests. Cheers!
