Current Setup
Receiver: Denon AVR-S750H
LCR: Pioneer Elite SP-EBS73-LR & SP-EC73
Surrounds: Monoprice 6.5" 4103 in-ceiling
Subwoofer: Premiere Acoustics PA-120
Room Size: 15 x 17 x 8
Material: 98% movies
I want to upgrade my subwoofer. My budget is $500. I'm looking at SVS SB12-NSD for $399 (Amazon), SVS PB12-NSD for $499 (Amazon), SVS SB-1000, SVS PB-1000, or VTF-2 MK5.
I eventually want a dual sub setup, but that will be down the road. I worry that the older SVS models will be difficult to find for a matching set later on.
Thanks for any advice!
My advice even though I'm still a bit of an audiophile newb myself is you might want to look into considering custom-built subs, it might cost more than 500$ but if you were willing to do it in chunks building your boxes first then buying your subwoofer driver and then picking an amp ,you might find the
flexibility a custom a build for future upgrades for a lesser cost by either upgrading only amp or your driver's an whether it might be involving going from 1 sub to 2 subs, or a bridged config for a very powerful singal, it would be worth considering I've currently got two 15in ported Audiopipes tuned
to 17hz and a driver sensitivity of 96db feeding them 775w at 2ohms each and a custom ported box which gave me 114db spl at 20hz to 115db spl at 100hz a very flat response with a light variable around 116db spl between 25hz an 40hz , my prevous config was in the same box but a 92db 4ohm driver
feed 525watts which gave me 97spl at 20hz an peak 108spl at 77hz so a
192$ new pair of drivers the upgrade was worth it
plus custom build does not have to be a cube shape footprint like some pre-built which for me take to much space an aren't best room placement opition for me and,more strategic room placement in your room layout May be might be worth considering ,
some companies if you look online have pre cut diykits of can build
you a box but it does cost a lot more sometimes. so consider putting the effort into doing it yourself might be worth it ,it was for me
just for exmp. my cost figs in chunks
my crown xls 1502 (8,4,an 2ohm output opitions) at the time $349.00 currently $389.00
the wood for both boxs togather 92$
my current sub drivers 192$ for the pair
218$ for 100feet of jsc 4awg high current wire cut into two custom 25foot runs
and 164$ in custom cut Aluminum Sheet metal the produced the pieces for the port an bracing for both boxs ,i just went that way to
achieve the smallest footprint possible for my room layout an maintain my ports structural integrity which i could do with wood
but thats me
