Room size is definitely one of the things you need to consider. Not all manufacturers rate theirs based on cubic feet, but with most of the internet direct companies, you can give them those dimensions and your personal needs and they will recommend one that should fit the bill. Obviously, the second question would be: what is your budget? I'd expect to be looking at the $400-500 range for that size room minimum.
