Sub isolation from floor-pros/cons?
cerwinmad
cerwinmad
I have a CerwinVega VE-28s sub. it is dual 8inch front firing, with a rear port. I have had it sitting directly on carpet, no feet or spacers. i have now got it sitting on four rubber cylinders approx 1.5 inch high x 1 inch diameter. I was wondering wat influence this has on its performance. also can some one explain wat "bass loading' is? i heard some people use weights? or is it a old wives tale?:D thanks, Rob.
MDS
If the sub is sitting on something that could vibrate, isolating it somewhat can have a miniscule effect on dampending those vibrations but in general bass will go through anything because the wavelengths are so long.
cerwinmad
cerwinmad
ok, yeah i didnt have any vibration probs, just thought it might be a good idea. so basically theres no difference between havin sub sitting directly on floor and havin it slightly raised on feet?
E
Exit
I agree that the rubber feet don't do anything sonically. My subwoofer sets directly on the carpet, but it has a hardwood floorplate which redirects the downward firing subwoofer's bass. I don't think the hardwood plate is necessary either but it is a nice design feature that looks good and protects the speakers.
E
Exit
Also, I had a BIC 18" downfiring subwoofer and it set on hard plastic feet. In my first house it fired into hardwood floors and in my second house if fired directly into carpeting. I did not notice any difference in sound quality between the two installations.
