About a year has gone by since I posted this. I found the T/S parameters for these subs. I already suspect that these are low quality car subs that really have no place in home A/V. I'm really posting this here to have my suspicions confirmed. Here's the T/S parameters:
Freq response: 30Hz-500Hz
Amp. Power Range: 20W-500W
Continious Power Handling: 250W
Peak Power Handling: 450W
Voice Coil dia: 2,0" (51mm)
Nominal Impedance: 4 Ohms
Sensitivity@2.83V RMS@1M: 87dB
Driver Displacement: 0,09 cu.ft. (2,55l)
Thiele-Small Parameters:
Fs = 31Hz
Vas = 1,85 ft² (52,4l)
Qts = 0,43
Qes = 0,45
Qms = 7,55
Re = 3,3Ohms
Le = 0,6mH
Xmax = 0,480 in. (12,2mm)
Xpk = 0,866 in. (22mm)
Sd = 0,3724 Sq. Ft. (0,0346 Sq.M.)
Vd-linear = 0,000422 Cu. M.
Vd-peak = 0,000761 Cu. M.
