No point to do it that way. Some subs might have a bit of a gain advantage by using a splitter from a single pre-out for two (L/R) inputs on the sub if the pre-out level was particularly low. Your Denon (4400, right?) at least has separately adjustable sub pre-outs for level/delay so I suppose if you do want to use both at least make sure they're set the same.
