ducker
ducker
So if my sub is RCA. and the output on the Receiver is RCA... why do I read so many posts here and there about running Coax??? I'm guessing there are RCA - Coax converter plugs??? Coax is cheaper to run for longer distances then RCA, and maybe it is shielded? I already bought a 20' line of RCA to run in my basement from amp wall plate to the location of the sub wall plate...
but if I was to do this again, I think I would look down the Coax road... So what am I missing here with Coax and Sub input?
W
warpdrive
I'll paste from bluejeanscable.com to save me some typing
Some people think "coax" or "coaxial" cable means "antenna cable," or "cable with F-connectors," or some such thing, but coax is a much more general classification. Any cable which has two conductors which share a single common axis is a coaxial cable--a center conductor, accompanied by a shield, the two being kept apart by a dielectric and wrapped in an outer jacket. All common video cable types are coaxial cables, though that's harder to see in some than in others--for example, s-video cable typically is two mini-coaxial cables combined either in a common outer jacket or a zip-cord type arrangement.
So the common cables you see with RCA plugs are coax cables. The ones you use for Antenna/Cable signal are also coax. They just have different types of plugs, and the Antenna type are shielded.
nibhaz
nibhaz
RCA is the type of connecter. Coax is a cable configuration. What the post are referring to are coax cables terminated with RCA connectors. Hope this clears it up for you.
markw
Once again...
"I already bought a 20' line of RCA to run in my basement from amp wall plate to the location of the sub wall plate..."
No, you probably bought 20' of coaxial cable.
It may or may not be already fitted with RCA connectors on the end. In that case it would be more accurately described as 20' of coaxial cable with RCA plugs on the ends, but not 20' of RCA.
It could just as likely have had "F" connectors on the ends for use in OTA or CATV RF signals. In either case. it would still be coaxial cable. Would that now be referred to as 20' of "F" connector? I think not.
"coaxial" is a type of cable which consists of a central conductive strand, usually copper, surrounded by an insulator which is, in turn, surrounded by another layer of mesh, foil or some other conductive material. Generally, this ihas an outer insulation as well. Generally, this is 75 ohms impedance for audio and video purposes.
IOW, "coaxial" is a cable type. RCA is a type of connector.
Connectors go on the ends of the cables. Generally, the type determines it's usage.
It can be used to pass various INFORMATION, or signals. Now, as far as what information these can pass, here's a brief primer.
When outfitted with RCA plugs on the ends, this can be used for composite video signals, component video signals, digital audio signals, analog audio signals and pretty much anything else.
When it's fitted with "F" connectors, it's usually used for CATV or OTA antenna signals.
Isn't this covered in one of re FAQ's? If not, it should be.
ducker
ducker
I didn't see it. I'll review the FAQ's again... if it is shame on me for pestering you all... But awesome outlines markw.
thanks
thanks
Not to worry. We are here tp be pestered :D
Not easy to navigate and find your question in the FAQ section ;)
L
Leprkon
I think alot of people will run Cat 5 or R-6 cables in their wall because it's easier to work with. You can always put whatever connectors you want on the ends. :)
If I only knew then what I know now :D
ducker
ducker
so pretty much I could use whatever wire in the basement(inwall) that I want... geesh and I thought I was smart for buying the Carol wire at HD. I could of gone with something even less flashy!
Shinerman
Shinerman
I ran Carol 2 conductor insulated cable from parts-express in my walls. It was a great price and seems to be very good quality cable. Easy to pull through walls.
Shinerman
ducker
ducker
I think it was only .21 a foot at HD. 14gage. I wanted 12, but they had a sale on it, and none of it stock...
