Rony
Hi.
What is preferred:
1. Using internal Blusound NODE’s DAC 24 bit/192 kHz OR
2 Using BETTER EXTERNAL DAC ( Non MQA certified )
24 bit/96 kHz
Thank you.
Trell
Trell
First I'll look at the quality of the streaming service and its content.
Rony
I’m with Tidal
MQA or not. Don’t understand when MQA is in use. On the BluOS app I chose Master.
Trebdp83
Honestly, if quality two channel hi-res and lossless tracks are a priority, Qobuz is tops with Amazon Music a very close second.
The most annoying thing about Tidal is that each version of an album is a separate selection. So, throw in Dolby Atmos and there may be as many as three selections for one album.
If Dolby Atmos is a non issue, Qobuz wins. Everything sounds good there. Get a free trial and check them out. No “second unfolding” of MQA necessary from a device for real 24/192 hi-res tracks using Qobuz or Amazon Music Unlimited.
Rony
Qobuz is not available in my country.
Is Amazon Music can be streamed hi res with Blusound NODE at 24/192 ?
Also do I need to use the NODE’s internal DAC ( connected to an external processor vie analog OR to use the processor’s DAC ( better then the NODE’s ) connected via Digital Coax cable ?
Trebdp83
I believe Amazon Ultra HD(24/192) is supported on the Node. You can go either way with DAC.
F
FrancesPham
Yes, Amazon Music has a high-resolution streaming option called Amazon Music HD.
Verdinut
Verdinut
Hi.
What is preferred:
24 bit/96 kHz
Thank you.
You don't need more than the CD audio format of 16 bit -44.1 kHz. A 24 bit -96 kHz audio format falls into audiophoolery. This is fully explained here:
Bucknekked
Bucknekked
Thank you @Verdinut
I was afraid all this hi rate business was going to go on and on and on as if it were worth something.
