Static noise from speakers/receiver
creed37
<font color='#000000'>Need help. &nbsp;I have a home surround sound system set up in my house. &nbsp;I have a Kenwood VR-3080 receiver, B &amp; W speakers, Pioneer sub, and JVC DVD player. &nbsp;When I play a DVD, I get a static noise/buzzing sound that comes through the speakers while the audio from the dvd is playing (but does NOT happen when I play an audio cd through the dvd player). &nbsp;This static noise gets louder and louder as you turn up the volume. &nbsp;I have checked all connections to the receiver and speakers; I've even replaced the speaker wire and the optical cable, as well as cleaned the connections, but that didn't solve the problem. &nbsp;Sometimes if I jiggle the speaker connections to the receiver, the static noise will soften, but then will eventually become loud again.
Has anyone had a similar problem before and know what I can do to remedy the situation? &nbsp;It's really annoying during quieter parts of movies.......thanks!
Crred37</font>
Z
zumbo
<font color='#000000'>Check to be sure you have selected bitstream for output on your dvd player.
</font>
G
Guest
Guest
<font color='#000000'>I did check the bitstream selection, but that still didn't remedy the situation.  Any other thoughts?
Creed37</font>
Z
zumbo
<font color='#000000'>Try it without the optical. Use analog RCA's just to see if that may be it.</font>
Z
zumbo
<font color='#000000'>Not a ground loop. This would be constant.</font>
creed37
<font color='#000000'>Could it be that my receiver is just not powerful enough?</font>
