Stage 1a complete!
Man, my system just gets better and better sounding all the time!
Before starting with the Helmholtz, I thought I'd integrate my sub for two-channel music. After a bit of puttering about, I finally settled for the results linked to below, and which I'll get to in a moment.
I've included some of the results from my recent
review for comparison and have adjusted the time on the waterfall plot to make this easier. However, because I've had to move the traps around a bit to get the best results with the sub
integrated (I now have one MondoTrap, 2'x4' MiniTrap and 2'x2' Minitrap in each of the room's four corners; the side and ceiling MicroTraps remain in the same position as before, because the couch, front left and right speakers are also in the same position as before), the two sets of plots can't be compared
explicitly. That said, they may still be compared
qualitatively, and that is what I will do.
Ok,
this was my previous low-frequency time-slice. Apart from the room's first axial mode centred at approximately 40Hz, the rest of the graph is reasonably smooth with an average variation of say ±3dB. Great!
Apart from the fact that
overall, the response falls with frequency.
I'd assumed that this was perhaps due to my front two towers increasingly struggling to put out deeper bass, but as can be seen from the plot with the sub
integrated (crossed at 80Hz) with the towers, I guess this wasn't true because from approximately 65Hz and above (though the towers are only reproducing 80Hz and above in principle), the response is fairly level. I'll come back to the hump around 200Hz later.
Comparing the
previous waterfall plot to that with the sub
integrated shows just how flat my response is from approximately 65Hz to 180Hz. The massive blade of the room's first axial mode at approximately 40Hz is very apparent.
Again, the
previous one-third octave plot for higher frequencies (which is a fair indicator of the response the ear actually hears) is nowhere near as good as it is
now. By joining up the
low-frequency time-slice plot with the
one-third octave response plot for the
integrated sub, you can see that the hump around 200Hz actually extends from about 180Hz to 250Hz with a peak level approximately 5dB above the average of say 82dB. Whilst this isn't ideal, I wouldn't say it's a disaster either.
The resulting sound is, I must say, quite spectacular. I had friends around last night and we were going through tunes which sounded so rich in bass (from a flat-ish response) yet at the same time so incredibly
clean (from a quick decay due to absorption) at the same time.
By the way Ethan, in answer to your unasked question, yes, I'll still be going for a Helmholtz.
That room mode must die!
Speaking of questions, I have one of my own:
Take a look at
this low-frequency time-slice overlay of just the front towers reproducing a full-range signal (Direct Analogue mode) compared to that with the sub integrated (2ch mode). Note that these particular responses
can be compared explicitly.
I know crossovers aren't brick-wall filters, but given that the crossover is set at 80Hz, why is there a difference in response
above 80Hz? I thought that the crossover would only attenuate the front two towers' signal from 80Hz and
below. Can anyone explain what is happening here?
