Splicing Speaker Cable???
Omega Supreme
Omega Supreme
I am about to move my HT to another room. My surround speaker cables will not be long enough for the new room. Is there a problem with splicing speaker wire? I currently have 12ga (bought from bluejeans.com) and I will be about 10' short on each run. I would really like to just buy an additional 20' instead of buying +/-80' and scraping my current cable. Let me know what you think.
MDS
It's ok to splice speaker wire together, just make sure the connection is solid to avoid separating them if you ever pull on them.
You can do the twist tightly and wrap with electrical tape method or use butt splices. Shrink wrap tubing around the splice would be nice to ensure it doesn't come apart easily.
BMXTRIX
BMXTRIX
I use electrical caps when I have to splice speaker wires...
It works great, holds stuff together. I typically tape the wires after they are capped to ensure zero chance of separation.
Omega Supreme
Omega Supreme
Thanks for the replies. Ive got plenty of wire nuts laying around so Ill give those a shot.
BMXTRIX
BMXTRIX
Wire nuts... Cripes! Why couldn't I think of the name. To many kids driving me caps...
...I mean nuts.
