lovinthehd Audioholic Jedi Sep 11, 2012 44,878 0 113 Oakridge, OR Nov 10, 2020 #21 Speedskater said: 'SPL' meters typically have large diameter mic elements. They also have 'A' & 'C' weighting and Slow/Fast response settings. And are stand alone calibrated measurement meters. Cal mics typically have small diameter mic elements. The amplification and frequency response correction is done farther down the line. I have not used cell-phone mics. But I see problems with polar patterns, with ability to exactly reposition the mic and to operate without people in the room. Click to expand... Thanks for the clarification and expansion. By the appearance of some spl meters I've seen thought it more likely similar sized mic elements..... My software has the various weightings as well as fast/slow response, tho. As well as a calibration file for my mic. For really high spl I'd get something meant for it, tho.
mtrycrafts Seriously, I have no life. Aug 19, 2004 23,550 0 113 Nov 10, 2020 #22 here is the RS correction table. This was also supported by the audio club whose members designed the ABX box: Radio shack SPL meter - correction table - Gearspace.com Last night I read up on the RS Digital SPL meter and it's issues. surprise surprise, for 50 bucks, it does not measure uniformly across the entire spec www.gearslutz.com
B bruin62 Full Audioholic Feb 25, 2006 384 0 18 Nov 14, 2020 #23 TankTop5 said: What is your definition of inexpensive, that means different things to different people Click to expand... What I meant was if a cheaper one works just as well as a expensive one why buy the more Expensive one Reactions: TankTop5
