speakers suggestion
N
Niranjan
in projector's i am selected Benq w1070+
Benq w1070 is 1149
Benq w1070+ 1294
i have seen some reviews in youtube many people saying Benq is good in budget and color quality.
tyhjaarpa
tyhjaarpa
In these forums I believe most people have either Marantz, Denon or Yamaha receivers. Pricing in different places can vary quite a lot for various reasons. I don't know why Onkyo is expensive in India, perhaps they think it will sell at what ever price they put on them.
For projectors my knowledge is close to none, you should try Projectors & Screens section of these forums to ask about projector information.
Tried to look up options from google but can't really find anything. I believe there is one retailer in India for SVS but they don't list prices on their site. Did you ask them for the price, if so how much they ask for PB-1000 and SB-1000? And what is the price for Polk DSW PRO 660 wi for reference?
Do you have links for your local stores so we could see what is available and at what price? Or brands that are available for you?
N
Niranjan
In india polk dws pro 660 is costing 29000 inr. i ask one of my vendor who sale the polk speakers he also saying SVS
in svs gives good quality then Polk ?
How is martin logan dynamo ?
ebay.in
amazon.in
tyhjaarpa
tyhjaarpa
ebay.in
amazon.in
SVS subs will give much better performance for value compared to Polk subs generally. http://www.acoustic-arts.com/brand/svs/ I would contact these guys and ask how much they sell SB/PB-1000 and SP/PB-2000 for.
Martin Logan makes some good subs, but they are generally quite expensive. To compare with said SVS subs you would need to get Dynamo 700 or 1000 and I would guess that they cost quite a lot more than said SVS models.
N
Niranjan
Just i go thorough the acoustic arts site. it's good. so svs bookself also good ? which model is good center and bookself ?
for home theatre room for good sound quality wooden floor required or normal floor with carpet is enough ?
N
Niranjan
Right now my vendor don't have stock of Polk bookself so i have to wait till next week.
if suggest to go for svs speakers i will ask my vendor what is the pricing if their is no much difference i will go for svs.
in svs sub what is the difference in SB series PB series
tyhjaarpa
tyhjaarpa
SVS bookshelf speakers offer good quality and some people in these forums have SVS speakers and they have liked them as far as I know. I think the Prime series is in your budget when taking Bookshelf as front, center and either bookshelf or satellites as surrounds, I would go with bookshelf as surrounds as well but some might say it doesn't matter that much. Ultra series is more expensive and I believe is over your budget. Which ever model you choose, take the center channel from same series as front speakers for better match.
Floor material doesn't really matter, if you have hard wood floor add carpet(s) to damped reflections.
N
Niranjan
which one is good SB or PB
tyhjaarpa
tyhjaarpa
SB is sealed and PB is ported. Commonly sealed subs are seen more musical than ported subs. Ported subs how ever have more low end extension and for that reason are more favoured in hometheater usage generally. How ever both subs work well in both scenarios. So it really depends on do you want more control or more low end extension which ever is best for your needs. I myself have 12" sealed sub and it does really well on HT usage as well.
N
Niranjan
Thank so much your genius i don't anything about speakers after you explaning i got bit knowloadge about speakers.
but still i am in confuse which one i have choose SB or PB if possible please suggest i watch most of the English movies DTS and Dollby i like deep bass please suggest.
tyhjaarpa
tyhjaarpa
If you watch more movies than listen music and movies are more your thing then I would get PB. If you focus more on music and want your music to sound as accurate as possible then get SB. As you mention that you like lower bass then PB might be more suitable for you.
Far from genius, just sharing my knowledge.
N
Niranjan
Hi ,
i am buying another pair of speakers for my office purpose my vendor is offering it"a 5.1 setup i am planning 20/12 room size
jamo hsc 3 626 (5.0) 58000 INR
jamo hsc 3 526 (5.0) 49000 INR
Polk is tsx330,tsx110,tsx250C (5.0) 57780 INR
Which one is worth to take suggest one model
tyhjaarpa
tyhjaarpa
Out of those options I would go with Polk. Did you contact the SVS retailer for prices yet for subs / prime speakers? It is also worth to listen those speakers on your retailer and see which sound you like more. As in the end it is you who will be listening to them and what sounds best to you is most important in that case.
N
Niranjan
yes i contacted svs retailer in india svs pb-1000 costing 40k+ right now out of stock.ok fine
in India every one saying svs is expensive.
except this POLK,svs,klipsch, what brands we have in low budget, i haven seen poineer but i didn,t like much if you suggest any other speaker makes in budget .
did you listen the jamo speakers sound quality ?
tyhjaarpa
tyhjaarpa
I haven't heard the said Jamo models. But in my experience Polk would be better choice. You should go and listen them yourself and see do you like the said Jamo models or Polk models better. Concentrate more on high/mid sounds than low sounds as you are getting a sub so they arent so important in speakers you choose. For the price of SVS PB-1000, when I convert INR to EUR it is same price as it is here. Pretty sure it is still good bang for bug there as well and better value than Polk subs.
Edit:
Pioneer SP-PK52FS 5.0 setup is good budget setup if it is available there and shouldn't cost a leg.
N
Niranjan
Can you please explaine how to select the Av receiver
Hi how to choose the right Av receiver for. Correct speakers
Av receiver is capabuilty for floor standing speakers like watts I am asking
For example
Marantz sr6010
  • 110 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
Polk tsx440
8ohms
20-200watts
Dose this amp can handle this floor standing speakers along with other surround speakers .
hemant
dude...tell me the final set u r planning to buy..with price of each too... m in delhi.. whr r u frm..??
