speakers suggestion
N
Niranjan
Jamo s426 or Taga Harmony tvs 606 SE which speakers is good
tyhjaarpa
tyhjaarpa
How big is your room? Do you mainly listen to music or movies? Is this going to be stereo setup or multi channel setup? What is your budget? Is there any reason you are between those 2 speakers? What amp you have to run those speakers?
N
Niranjan
12 by 12 by room
MAIN FOR MOVIES.
MULTI CHANNEL SETUP
I HAVE ONKYO 7.1 AV RECIVER
my budget is 35 K with sub woofer. i got one offer
1. jamo s426 for Rs.27000 (400$)
2.Taga Harmony tvs 606 Rs.27000(400$)
i am in confusing which one i should go and second thing which one will give good surround. i am planing to go subwoofer polk psw125. could you please suggest good one are if u suggest anything i will think about that plz.
N
Niranjan
First i am planning to go for Bookself speakers in FL-FR many people suggest me to go for floor standing is right ?
In book self speakers i have choose Polk tsx200 series for front and tsx110 for sorround and center tsx250 sub psw125 is good or right i don't i am beginner. and i am selected Benq w107+ projector .
after that i got this jamo and taga harmony offer so i am in confuse.
tyhjaarpa
tyhjaarpa
Little confused about your budget.. I believe there are many better options than those you have listed, specially for sub. Are you going for 5.1 setup? What is your total budget? Your location might help as well for choosing what is available.
N
Niranjan
yes i am going for 5.1
i use for Home purpose
my budget 500$
N
Niranjan
sorry to ask you like this jamo s 426 (5.0) vs tAGA harmoney tvs606 se(5.0) which one is good naturally in your opinion .
tyhjaarpa
tyhjaarpa
I would take a look on Pioneer SP-PK52FS 5.0 and Dayton Sub-1200 or Dayton Sub-1500 for your budget.
Out of your options I have never heard of Taga and I haven't heard those Jamo speakers either, so I can't say much about them. If I had to choose between them I would pick the Jamo just because I know the company.
Edit:
If you have those said speakers available locally, go and listen to them if those are your only options. What ever sounds best to you is better pick.
N
Niranjan
Thank you so much for your quick replay and what about Polk tsx440 & tsx330
tyhjaarpa
tyhjaarpa
Sorry I somehow missed your question about Polk. I would say Polk is better than said Jamo/Taga speakers even tho I haven't heard them.
I would pick TSx 330T over TSx 440T for 5.1 usage as you have sub for low extension. For stereo usage without a sub I would pick TSx 440T for low extension. For surround you will be fine with either TSx220B or TSx110B and for center TSx250C would do well. How ever with a good sub you will be fine with TSx220B as front and TSx110B as surrounds. You don't necessarily need tower speakers if you have good sub to go with bookshelf speakers. I believe with said Polk speakers you would use your whole budget for 5.0 setup alone? Could you spare more for sub? Or perhaps buy the 5.0 setup now and add the sub when you can afford one. For good sub you would need around 500$ budged as well.
N
Niranjan
Polk which model subwoofer you recommend ?
even other models also just tell which one is good
tyhjaarpa
tyhjaarpa
I would recommend getting one of these subs instead of Polk subs for better performance vs value:
SVS PB-1000
SVS SB-1000
HSU VTF-1 MK2
N
Niranjan
HI I AM PLANNING TO BUY MARANTZ SR6010 HOW IS IT ?
tyhjaarpa
tyhjaarpa
SR6010 is a good unit. But you said you have Onkyo 7.1 receiver already? Why do you want to purchase SR6010? Do you really need the SR6010?
N
Niranjan
No this is not for me this theater purpose
we need to connect 7.1 input in separately
N
Niranjan
compare to Denon avr-x3200w this good right or both same in sound quality
tyhjaarpa
tyhjaarpa
Didn't really get your point. So you are looking receiver for some one else?
How ever, is there some must features in SR6010 that are not available in SR6008/6009? As you can find SR6008/6009 for a lot cheaper than SR6010. Comparing Denon and Marantz from same price range there shouldn't be much changing on sound quality at all.
N
Niranjan
in my location svs subwoofers are little bit expensive my vendor suggested
polk DSW PRO 660 wi how is it
tyhjaarpa
tyhjaarpa
Where are you located? Perhaps we can see what is available for you and at what price.
N
Niranjan
why most of the people will use Onkyo Receivers ?
what is the difference between home theatre package like Onkyo HT-S7705 in my country it is costing 1400$ usd 5.1.2
at the same time for that cost i am getting Marantz or Denon Receiver with 7.1 system which is better in you opinion
i know onkyo is giving Dolby enabled speakers
still i don't understand what is the difference
