Since I'm on a different market from most of you, I can’t just ask you to recommend me some speakers. I have to see what is available to me and ask here how would you rate them. I hope you’ll have the will and time and I’ll try not to be difficult.
The question is about speakers, the same as discussed in the “How Do You Read A/V Grades” thread. Since that is obviously no longer the subject of the conversation, I decided to start the thread here in Speakers and move the debate. I hope no one got banned for starting a few threads on the subject
My decision so far is to try and find cheaper KEF LS50 which by the standards of many of you, sound quite good (or even better than that) and are relatively easy to drive. This will take some time.
In the meantime, these are available to me:
Revel Concerta2 M16
2-way 6.5" Bookshelf Loudspeaker
Crossover Frequencies
2.1kHz
Enclosure Type
Bass-Reflex via Rear-Firing Port
High-frequency Drive Components
1" Aluminum Tweeter with Acoustic Lens Waveguide
Nominal Impedance
6 Ohms
Input Connections
Five-way binding posts
Low Frequency Extension
55Hz, 50Hz, 45Hz (-3 dB, -6 dB, -10 dB)
Low-frequency Drive Components
6.5" Aluminum Cone Woofer
Recommended Amplifier Power
50-120W
Sensitivity
86dB (2.83V @ 1M)
Dimensions
14.75" x 8.6"x 10.76" (37cm x 22cm x 27cm)
Weight
16 lbs
Now I have to ask you to compare it with LS50. I might get these for 900-1000$ (not cheaper). Is that a good deal, is this a “900$ LS50” so to speak?
FOR LATECOMERS (joining late to the conversation whatever your excuse may be
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I’m looking for a pair of bookshelves. They should be as clean and natural as possible; I’m not about “lie to me beautifully” approach. Old fashion stereo with a couple of new connections is what I’m after. Mostly for music - wide range, from electro pop to acoustic (very little classical), I will play my movies with sound coming out of these, but I’m not for 3D sound, immersion, atmos, centre speakers and so on. Good old stereo for movies as well. Shortly after, these bookshelves will be accompanied with a sub to complete a 2.1 stereo system (hopefully with an amp that will have an USB input leading to a decent DAC for my PC digital music archive).
This is for my living room. It is a 22 square meters (237 square feet) room that has very little furniture for the time being and one entire side of the wall is in huge windows (not good I know). They will be placed along the wider wall directed across the width of the room, not depth (although I have a feeling the latter would be better).
I have enough room to place them further away from the wall. I’m not dabbling in DIY and am a bit hard on second hand. They should be new speakers for not more than 1000$.
To save you all some time these are available to me: PSB, Scansonic, Quad, Tangent, KEF, Klipsch, Dynaudio, DALI, QAcoustics, Triangle, Focal, Audio Pro, Boston Acoustics, B&W, Mordaunt-Short, Tannoy, Monitor Audio, PMC, JBL, Wharfdale, Gradient, Micromega, Usher and Acoustic Energy…
killdozzer
