speaker wire question again
Alex2507
Alex2507
well, altogether (estimating by eye) they seem to be bigger than the required 2.0+mm diameter. it's just that i have another gauge 12 that's a lot bigger.
Now I want to know why. Like I said, I bet Gene knows and you could check with monoprice. Either way, please let me know if you find out.
Yes, but if the strands are thicker and fewer, you have more air space and larger overall diameter. Besides, you have a precision instrument, use it:D Or, is it just for the display case:D
Do you have a solid 12ga house wire to compare it to?
mike c
mike c
and then, this monoprice 12/4 looks a lot beefier than the monoprice 12/2 i bought
which is why i hesitated opening the new 12/2 roll. (it sure was a good thing i bought them last year even though i had no intentions of using them)
i'll try to get a pic of all 3-4 wires: BJC 12/2, Harris Cable 12/2, Monoprice 12/4 and if i feel like opening the Monoprice 12/2
http://forums.audioholics.com/forums/showpost.php?p=482197&postcount=317
lol. yes i do have some THHN wire ... but here in the Philippines, they've always been specc'ed by their mm size. i.e. 2.0; 3.0
Rickster71
Rickster71
You're all on the right track.
It comes down to conductor area, measured in Circular mils. 12AWG = 6530 Cir. Mils. (stranded or solid, 12AWG = 6530 Cir. Mils)
The reason for the finer stranding in some wire types, is for flexibility.
So speaker wire and extension cords will have fine strands, and wire that's intended to be more permanent will have thicker strands or have a solid conductor.
My book of tables indicates that a 12ga is 2.053mm diameter.
Yes, circular mills works too if you have that info but that is not metric.
So, if you have a 2mm wire measured with your micrometer, that is 12ga, very close anyhow.;):D
