Speaker Stand ID Help
cpp
cpp
I've had these speaker stands for better part of 15 plus years and cannot remember the brand. The center column is round (circumference = 11") and hollow ( mine are filled with sand, and heavy) Anyone know ?
I want to remove the spikes and get to something that will not kill my tile floor.
Thank you
Never saw ones quite like that. The threading is likely to be somewhat standardized so pull the spikes off and see what size/threading they have (like take one with you to the hardware store to see what that is). Parts-express.com is likely to have some choices in rubber feet. If the base could sit entirely flat on the carpet, you might not even need feet at all?
I have these for my mains too. They are made by Dayton aka PartsExpress. Pretty sure they don't make them anymore. I have carpet though. I believe they are 1/4-20 threads, just remove the spikes and find some threaded rubber or slider inserts
or just cover up the holes with some stick on carpet/furniture feet.
