OK, After digging through a number of links, I have narrowed it down to these.. (Still have to go listen , of course , but since my nearest audio stores are 60+ miles away, I'd like to narrow it down before I go in quest of listening.)
Any futher opinions or insight?
BIC Venturi DV62si
43 Hz-20 kHz
3/4" poly dome tweeter
6" poly/graphite woofer,
Phase Tech Teatro 4.5
58 Hz -20 kHz (±3 dB)
1" soft dome
5.25" Vapor Deposited Titanium
SVS SBS-01
68Hz - 20kHz ± 3dB
(1) 1" (25mm) ClearSilkT diaphragm
(1) 5.25" (133mm) polypro. cone
xPhase Tech Teatro 4.5
1" soft dome
Paradigm Atom:
±2dB from 70Hz – 20kHz
19-mm (3/4 in) CMC™ dome
140-mm (5-1/2in) polypropylene cone, die-cast chassis
Paradigm Titan:
±2dB from 60Hz – 20kHz
165-mm (6-1/2in) polypropylene cone, die-cast chassis
Paradigm Focus:
25-mm (1 in) CMC™ dome
165-mm (6-1/2in) MPC™ cone, GRIP™ chassis
PSB Image B15
On Axis @ 0° ±3dB 50-23,000 Hz
Tweeter(Nominal) 1" (25 mm), Aluminum Dome with Ferrofluid
Woofer (Nominal) 5 1/4" (133 mm), Injection Molded, Metalized Polypropylene cone, Rubber Surround
PSB Alpha B
On Axis @ 0° ±3dB 65-21,000 Hz
Tweeter(Nominal) 3/4" (19 mm), Aluminum Dome with Ferrofluid
Woofer (Nominal) 5 1/4" (130 mm), Polypropylene Cone, Rubber Surround
