Hello, I need advice on setting up my living room. I’m going to be moving into this rental soon, and i want to plan out my home theater. I’m a college student so I’m going to be renting out this place for the next few years. I’m only allowed to make small holes in the wall to hang items.
Information about the room:
The floor is a thick carpet and the walls are drywall and the ceiling is 8ft high and is plaster. The living room is an open floor plan, so behind the magenta line is the dinning area and the kitchen. So ideally i would like to keep everything inside the designated area. There is a 3ft wide by 2 feet tall window on the left wall. I will be installing a drape to cover it. There are four of us living here.
Equipment: I got all this from HHGREGG during the liquidation (I was an employee). The total for everything was $670.
- 60UH6150 LG 4K HDR PRO 60”
- TX-NR656 7.2 receiver with Dolby Atmos and DTS:X
- Two Klipsch towers R28F
- Klipsch center R25C
- Four Klipsch bookshelf speakers R14M
- Klipsch Subwoofer R10SW
Both designs are in feet and everything expect the size of the speakers are to scale. The surround speakers will be on stands around 40 inches tall:
Option 1:
- Left and Right channels are at 22 degrees at 10 feet away from the sweet spot
- Surround Left and Right are at 100 degrees at 9 feet away from the sweet spot Toed in
- Surround Rear Left and Right are at 150 degrees at 3 feet 6 inches away from the sweet spot
- Center at 0 degrees at 10 feet away from the sweet spot
- TV 10 feet away
- Open space on the right side and 4 foot wide hallway behind
Option 2:
- Left and Right channels are at 20 degrees at 12 feet away from the sweet spot
- Surround Left and Right are at 110 degrees at 12 feet away from the sweet spot toed in
- Surround Rear Left and Right are at 160 degrees at 6 feet away from the sweet spot
- Center at 0 degrees at 12 feet away from the sweet spot
- TV 12 feet away from the sweet spot
- Open space behind and 4 foot wide hallway on the left side
Which option would be best overall? I understand that people sitting on couch 1 and chair won’t be getting the best experience. But i want them to have a good movie watching expierence too. What changes would you make? How would you sound treat the room? I’m leaning towards option 2 because i feel that it is better to have the large open space behind you instead of to the side of you. However, i’m sitting farther away from the tv. Would 7.1 or 5.1.2 be better in this case? I’m thinking about selling two of the R15M’s and getting Klipsch’s atmos module RP-140SA.
