Belaflek73
Ok what do you think?
Option 1: HSU research Ultra15 5.1 (1 ULS-15, 4 HB-1 MK2, 1 HC-1 MK2)
$1759
Option 2: HSU research 1 ULS-15, HTD 4 level 3 bookshelves, HTD 1 level 3 center
$1849
That ULS-15 looks awesome and its not huge which is a plus for me. I'm kind of bummed HSU research doesn't offer their MK2s in rosewood anymore. I think black is the only option. It doesn't make sense for me to get the sub in rosewood since its essentially hidden in the corner. To be honest I'm leaning towards option 1 but my reservations come from esthetic issues....which I know pales in comparison to sound quality. Not to mention somehow my budget increased again.
zieglj01
zieglj01
$1759
$1849
As far as the bookshelf and center speakers, the choice is yours
to make > I have my preference - however, I believe you will be
happy with either one. Good Luck!
Belaflek73
Ok, so just to be clear your preference is the HTD level 3 bookshelf and center, and then the level 2 surrounds. And stick with the sub from HSU.
Is that what you would do? I understand both options are pretty good.
zieglj01
zieglj01
Yes, that is what I recommended - and a good sub from HSU.
My sub preference/choice, depends on room size and budget.
The final decision still comes down to you.
