speaker newbie in need of help
pwngeboy
Hello, I'm looking to set up a system in my room it's medium sized about 16x22 I'm preffer a 5.1 system but thinking I should go for a 2.1 now upgrading later. the budget is about $400-500 since I'm still a college student I already have a reciever a Harmon and kardon gotten for 107 on ebay. I've heard good things about the speaker company are their tst-1s good.
Thanks,
m_vanmeter
for a nice entry level system it is hard to beat Polk Monitor series speakers and Polk CS1 or CS2 center channel speaker to match.
A pair of Monitor 50 towers and a TSC subwoofer would be a great 2.1
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=polk+monitor
http://www.thespeakercompany.com/Subwoofers-C17.aspx
add a Polk CS1 center channel and you have a very nice 3.1 system. Add the surrounds, like the Monitor 30's at any time.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290021
DD66000
DD66000
Thanks,
Being you already have a Harman-Kardon receiver, might stay with harman speakers (JBL, Infinity). Get good deals on their ebay store.
http://stores.shop.ebay.com/Harman-Audio_Home-Speakers_W0QQ_fsubZ20969481QQ_sidZ26519532QQ_trksidZp4634Q2ec0Q2em322
MUDSHARK
MUDSHARK
Contunue your e-bay approach. This will effectively double your budget by going used. See whats out there in Ascend, Axiom, and the mainstream brands. I have purchased used high quality speakers on e-bay several times. I recently won 2 Mackie HR824 monitors for less than 600, just half of the new price. Good luck.
G
griffinconst
You could find used Paradigm Monitor 9's in your budget and wouldn't need a sub for now. They rock and you could certainly build a 5.1 around them.
Sorry I haven't heard the tst-1.
Keep us informed.
pwngeboy
I will then I see some klipsch synergy center channels for 100 is this a good brand for I heard their the best for movie and game purposes but they cause listeners fatigue.
MUDSHARK
MUDSHARK
Yes, I would agree with that. That is the lower line by Klipsch and are they ever bright. Listener fatigue? Some would say they make the ears bleed. Not for everybody but Klipsch has their loyal following as do the other mainstream brands such as B&W, Paradigm, Infinity, etc...
Infinity lower lines are pretty good. You might do a search on Beta 20 to see what is out there. Also see if any used Paradigm studio 20 are out there.
adwilk
adwilk
Nice little setup Adam......
Yeah, both of those products are really great for their price point. You'd have to spend considerably more money to get similar performance from other products.
pwngeboy
Really they can make your ears bleed? But I do know by what you mean they are bright. I saw some klipsh speakersat best buy and listened to them the xr series and thier cs-700 they really aren't suited for music
