I read it, but about half way though everything got fuzzy and I forgot what I was reading. I understood a little of what he was saying but not enough to be able to,.... well, understand the overall picture.
I believe the nutshell is as follows:
Efficiency: power output, total, including ALL directions, for a specified power input.
Sensitivity: power output, for ONLY on-axis, for a specified power input.
Oh, people have already answered. Hm, I see you have already posted again. Ok. How about this analogy:
I have a specified power input of WATER, through my two identical water hoses, that are both putting out the same amount of water. However, one is using a wider nozzle, and its power is spread about more. The other hose is using a narrower nozzle, and the power is focused more directly out of it. IOW, If you sprayed me with both hoses, the narrower nozzle would make feel more pressure on any certain point of my body (higher sensitivity, as in ON-AXIS), than the other, even when the total output is identical when considering all angles. Well, I tried.
I think the whole Q thing he was talking about could describe the size of the nozzle. Sorta. You can instead think of two identical spray bottles, with different nozzle settings. Squirt vs spray. Same output overall, but when measured perfectly onaxis (perfectly in front of nozzle), the squirt is stronger.
