Would need to know more about the room and the intended placement to offer an opinion on them being a 'good choice'.
Timbre matching is most crucial with high frequencies. Dispersion, Directivity Index, even the baffle shape and diaphragm material, influence a speaker's timbre. This is also most crucial with L,C,R main loudspeakers, and is far less noticeable with surrounds.
If these are all soft dome tweeters, for example, then I would say you can safely assume they will blend well together.
