Speaker Cover Material
3
32cjones
Hi,
I have my center channel on a shelf on my entertainment center. My power strip and lot's of cabling are also behind the center channnel so I want to build a large speaker cover to hide the center channel, power strip, etc.
Does anyone know where I can buy speaker cover material? Any web sites out there?
Thank you
Davemcc
Davemcc
I got mine at a local sewing material shop. Any of the bigger type of these sewing shops should carry it. Just ask at the counter. If you don't know where your local sewing shops are, ask you mother or grandmother. They will probably know.
ParadigmDawg
ParadigmDawg
Yep, I have found it at several fabric stores.
E
EJ1
They carry it at Jo-Ann fabric stores. See if there's one near you.
jostenmeat
Hi,
Thank you
GOM, otherwise known as Guillford of Maine. That's what everyone uses, for anything like false walls in a dedicated theater, and is also used by both GIK and Real Trap panel companies for custom colors on their acoustic treatments.
