speaker binding posts .
Rony
Do speaker binding posts affect sound quality ?
Replacing the speaker original binding posts with different ones can do something ?
Thanks.
Thanks.
For Heaven's sake, just "pull the other one!"
You've been reading too many silly "audiophile" blogs or something. They'd have to be pretty defective to make a difference. Or do you have speakers with a normal set of binding posts and you want to add another set to provide silly passive bi-amping?
Rony
Understood. Thanks.
Yes, he needed that translated, and you provided it, thanks!
It is OK to wonder about these things and asking is the right way to find out before it costs you unnecessarily. If something sounds too good to be true, it probably is.
ryanosaur
ryanosaur
OK. I beginning to suspect troll-bot unit 107 is hard at work pulling strings and pushing buttons.
Speedskater
Speedskater
Only if the binding posts are corroded, damaged or defective will they affect the sound.
Same op said he has Focal Electra 926 but those clearly have dual binding posts.
But the Sopra 3s he was thinking about don't appear to have such (good for Focal to not include that stuff IMO).
