Hello
I need to buy a new set of HT/Party speakers as well as a receiver for my family room. I am a little lost because of the layout of the room. See attached image (its a bit small so i will provide some details)
1) The family room is 12X18 with 11ft ceilings
2) We have ut our existing 42'' TV above the fireplace and the couch is on the other end (so 18ft distance)
3) There are windows on either side of the fireplace.
I did some measurement and if i eat up all the space between windows the max i will be able put is a 65'' TV (ideally would like to do that as we sit far away from the TV).
Here are the requirements
1) The music has to be as loud as i can get within my budget (we host our friends and they like loud music). So i am thinking Klipsh or something loud.
2) Cannot put PA grade speakers as they have to look decent
3) Wife does not like anything on the floor so speakers have to be wall mounted. Enough space for center channel but not much for side speakers unless i get a 60'' or a 55'' TV
4) The side speakers are probably too close to ears so dont need to be that powerful
5) I can go with smaller 7.1 speakers and put downward facing speakers and put them on the side wall facing downwards.. this way we will need smaller speakers but very efficient (as we need loud)
My budget is around 2K for speaker and amp minus TV. Any advice on the make/model/setup of the sepakers and the amp.
