Just getting started to design a new installation in family room with TV. Not sure if I’m looking for primarily two channel listening or grow to include also “home theater” including the TV.
I’m hoping to not reconfigure the room seating arrangement drastically (WAF), so that immediately presents compromises, as seating is not well aligned for where I would foresee mounting the two main speakers.
Also, hoping to not intrude into the room much, I’m exploring my options for surface mounting speakers on front wall.
What obvious trade-off’s or errors am I making if I’m looking at using what are primarily marketed as bi-pole, surface-mount surround speakers, to use as my main front speakers? My initial studying suggests the bipole configuration should partially make up for seating that is “off-center” in the room, because of their wide radiation pattern. Also, since they are designed for surface mounting, that I will not drastically compromise their performance if I mount on the front wall.
What obvious mistakes does this approach make?
I’ve been studying Floyd Toole’s third edition, and this approach occurred to me.
Thanks in advance from a newbie.
