sound with netflix or should I say no sound?
L
landonspop
I have a pany DMP-BDT300 hooked up hdmi to my Mits tv, seen in signature.
When I play dvd or b-r disks I get sound....but netflix = pic only. I have tried all I can think of.
L
landonspop
No sound on netflix or you tube streamed
Can someone who is set up like me or understands my problem please look a my settings to see if I have made a mistake?
This is what I have set:
Setup>TV/Device
3D type........ Full HD
TV Aspect.... 16x9 full
HDMI conn
.... HDMI video mode.....ON
.... HDMI sub...... v.off
.... HDMI resolution..... 1080i
.... 24p output............ ON
.... HDMI color mode YCbCr ( 4 4 4 ) not sure how to set here
.... HDMI audio output...ON
.... Viera ....................Off
.... Deep color............. AUTO
.... Contents flag..........AUTO
Component Video resolution 720p
Analog output...............2ch+5.1ch
Setup>Audio
Dynamic range Commpression... Auto
Digital Audio Output
.... Dolby D/DolbyD+/.................... PCM
.... DTS/DTS HD.......................... PCM
.... BD Video Secondary Audio ........ON
PCM down conv........................... ON
Downmix.................................... Stereo
7.1 reformatting......................... OFF
High Clarity Sound...................... Enable
Delay ........................................ 0
please let me know if more info is needed
L
landonspop
have I stumped the pros???
This is what I have set: Panny 3D player
Setup>TV/Device
HDMI conn
Setup>Audio
bandphan
bandphan
I'd call panny tech support and check your firmware version to see if it is up to date.
L
landonspop
I do have latest update. I called panny, they just blamed the Mits tv..
Now I don't get sound at all even with DVD or BR or BR3d. I watched Cloudy w/.... sat night no problems.
L
landonspop
by pass your avr and and see if it works.
That is how it is. Just hdmi (main) through Mits 3D converter to Mits tv hdmi in.
I came here looking for people who actually use the stuff. Those so called reps do not know as much as I do. He didn't even know what the 2nd hdmi output did..
bandphan
bandphan
ok, if you take the 3d converter out of the loop is their a problem? BTW Im pretty sure not many here have the after market mitsu 3d add on. What year is you display?
L
landonspop
TV is a Diamond Series DLP 2008. This dvd player is very popular at avsforums.com and I did find out there it will work in 3D without converter. I will try tonight.
I would also set Dynamic Range Compression to OFF instead of Auto, though that may not be related to the audio issue - it should just be off IMO. Are you streaming wired or wireless? It sounds like a streaming issue, not necessarily a problem with the player.
L
landonspop
streaming wireless
Wireless streaming.
Well I kept changing things and got all of my sound working.
Somehow I turned off hdmi audio output which is what cost me the dvd and br sound I did have.
But I still had no audio on streaming video.
To get sound on netflix, I had to change hdmi resolution output to 480p. No other setting would play sound, not even AUTO. So I guess I have to change this setting between playing netflix and dvd/blu ray discs.
Thanks for all the help. Hope this helps somebody. Maybe I can get a job with Panny, no one there told me this. They blamed it on the tv or netflix.
