I've been reading more about Canton and I really like what I see (I have kind of a bias for German made products). Do you have any experience with their 50k center unit? That would put me over budget, but I could probably wait on a TV if I could get fantastic audio to a place where I don't need to upgrade
That is a really nice center speaker, but it is mono and you would lose the sound stage afforded by stereo and if music is important to you, you want that. That is also part of the problem with a soundbar is they are typically around 36" long (giving you about 30" separation between the left and right speaker) and usually have drivers that max out around 3". Those are big compromises to sound quality!If you sit 6 feet away from the speakers, you would want about 6' between the speakers to give you a good soundstage!
Help me understand your room!
Is this new construction? A converted container for a "tiny house"? A trailer (not likely with 12' ceilings)? An apartment (perhaps converted in an older home)?
The reasons I am asking is to know:
1) Do you have easy access to install wiring in the walls ceiling? Do you have the skills to place wiring in wall? Do you mind exposed wires running around your room, under carpet, etc.
2) How close are the neighbors? I would generally steer you away from spending more of your budget on the deeper, more powerful subs if you are going to be pissing off neighbors (but if that is your thing, we can set you up)!
