mathyou9
I'm looking at buying a 5.1 sound card with S/PDIF output. Because of a ground loop I have, I would like it to have an optical output. However, a ground isolator for my cable line will solve the ground loop issue, so if it only has a digital coax output, that should be fine as well. And of course, if it has both optical and coax outputs, all the better. I'm not needing anything overly expensive, just a decent card that works.
Any recommendations?
Thanks
Thanks
