I was hoping some individuals can help me answer some sound calibration questions.. I am a newbie with sound calibration (been using my system for awhile now without relizing anything about it until I read up on calibrations). My setup is the follow:
JBL PB 10 Subwoofer
JBL S310 II (Front and Left Floorstandings)
JBL S Center II (Center)
JBL S 36 II (2 Surrounds)
AVR 525 Harman Kardon Reciever
I ran through all the sound tests for Avia with a sound meter and all of the tests seem to have gone good but wanted to see if anyone thought my settings were wrong or somewhat off base since this is my first time calibrating my system.
Front and lefts are set to small, x-crossover is set to 80 hz and my sub crossover is set to 40 (not sure if this even is a factor when FL and FR are set to small). I moved my sub's freq. dial to max and phase is 180. Im not sure where my dip switch that states "Normal" or "LFE" should be. I set it to normal assuming LFE means its both sub + FR + FL ? All of my audio readouts at -25db were around 72-75 weighting C slow response on the meter so according to AVE it seems pretty good.. The volume of my sub has a total of 6 dots at each 6th, and im at 4/6 on the volume dial to achive those db readings on the normal sub tests with Avia. On the Avia test however that goes down in Freq. when it hits around 60ish it boosts to 80 db on audio meter but im assuming thats normal? My main questions are do those settings seem relisticly correct and should is my sub volume up too high for normal playback or is it whatever achives the db readings ? Should I lower my crossover from 80 to 60 possibly for my speakers? Thanks to anyone who can give me any input since this is the first time im doing this!!
Chris
