<font color='#000080'>Is it a number you're looking for?
Does it play loud enough for your room? Do you notice any problems when you play back music or movies? What speakers are you using?
To give you an answer you'd have to put the unit on the bench and measure the output, though I'm sure similar Sony receiver measurements can be found online.</font>
