After messing around with LPs on Saturday, yesterday I decided I needed to update the index for the two Sony CDP-CX355 CD changers. I used to be pretty diligent about entering each new CD into the index and assigning a slot in one of the changers. Wellll, I got kinda lazy on that over the last couple of years. After buying a new CD, I would immediately rip it to a FLAC file for playback over SONOS. Then, the CD would end up in a cupboard or drawer.
So, I gathered all those CDs together and started entering them into my index - it's just a table in a Word document with the artist, album title and CD changer slot number. When I added them all up, I had 616 CDs...and CD changer capacity for 600.
Not only that, the carousel on one of them was struggling to rotate as I looked for empty slots...and then stopped rotating altogether and "Table Error" came up in the display.
What to do? A Google search lead to a Youtube video about trouble shooting. First thing is to open it up and look at the rubber belts (there are two). One of mine was clearly broken and the other didn't seem to have much tension, so probably stretched. I probably cursed myself by teasing
@Alex2507 about stripping
his changer down.
There was nothing for it, but to take all the CDs out. So, dig the boxes of cases out of storage and start removing from the changer. The carousel is not easy to turn by hand, so I don't know if there is/are any other problems with it. Once I finish removing the CDs - of course, not all the cases for the CDs in that changer are in the same boxes
- I'll need to do a partial stripdown to remove the carousel to access the belt pulleys and see if there are any other obvious mechanical issues with it. If I don't see anything else, I may take the risk of ordering replacement belts - C$30/pr - and putting it back together.
If it works, I still have a capacity problem. If it doesn't work, I have a BIG capacity problem...
