SONOS Playbar, SUB, and Play:5 Review
  • Thread starter Thread starter gene
gene
gene
Audioholics Master Chief
Administrator
Jul 1, 2002
10,226
0
120
52
Florida
www.audioholics.com
If you’ve been looking at wireless whole home speaker solutions recently, you’ve probably come across SONOS. Started in 2002, SONOS’ goal was to reinvent home audio for the digital age by connecting devices in multiple rooms for seamless integration. With the multitude of wireless speakers flooding the market with dozens of streaming options will SONOS stand out? Read our in depth review and check out our YouTube video of their Play 5 wireless speaker and Playbar soundbar with wireless subwoofer to see if SONOS is the right multiroom speaker system for you.
Read: SONOS Playbar, SUB, and Play:5 Review
Sounds like you may not have seated the power cord in the Play 5 II correctly. Mine is extremely difficult to get out and requires quite a bit of wiggling and pulling to remove it.
Hi Gene, Thanks for the review. I was just thinking of starting a thread to see if anyone here uses Chromecast and what their thoughts on it is?
I just picked up a new internet radio, GD Mondo Plus, with built in Chromecast. As some might remember, I loved my GD internet radios. I have an eclectic taste in music and most the big music providers just don't go that deep into tracks or even genre's. It takes a little footwork, but you can find some amazing stations out there, with very good quality too. Fusion 101 is one of my favorites.
Going forward, some of the music providers are not allowing built-in (native) apps. Pandora is one of these that is not allowing devices run Pandora as a native app.
The solution for GD was build Chromecast into their devices and then you use your smart phone (i or droid) For those who don't know, there's a little button in the apps that then transmits what's playing on your phone to your Chromecast enabled devices. Actually setup was unbelievably easy. Once you Chromecast enabled devices is running, it doesn't need the phone anymore.
At this time I'm still kind of up in the air about it. There's a wealth of Chromecast enabled apps. I can add a Chromecast dongle for $35 toentertainment systems which will then allow multi room music. The downside is you need your phone, which becomes a remote at this point.
With Chromecast and Chromecast Audio you can connect to just about anything. But, there's extra steps involved; you just can't turn on a device in a room, channel select, and have it work. This may not be an issue when setting up for multi room. It's more of a nuisance when you walk into a room and just want to turn on the device to your favorite selected channel.
Sorry! I went on longer than I thought and probably should have started a new thread.
I have been selling and using SONOS for 6 years and it's the most complete wireless system out there. Every audio manufacturers have a wireless system to offer. Lots sounds as good and some better than SONOS but the mesh network and ease of use make it number one. Their customer service is awesome which helps if you have the connection issues you are talking about, and is usually related to Wi-Fi.
