In case you are waiting on a second opinion, Ski2xblack is right.
That Denon puts out 110 Watts with 7 channels. If you are using it in stereo, you are not likely to push it's limits unless your speakers are extremely difficult.
If that is the case, I'm not sure you want to go vintage, because back in the day, I didn't see much (if any) testing at 4 ohms. It would be rash of me to say vintage gear is weak with lower impedance, but it would be rash to buy vintage without verifying this ability.
However, since you have the opportunity to audition units at home, why not find out for yourself?
Only work with one channel (L or R). You can run a cable from the "PRE-OUT" on your Denon to the CD or Aux input on the new candidate. Of course, set all EQ controls flat. Hopefully, the candidate unit has a remote with a mute button. Put both of your speakers in the center of your room immediately next to one another, connect one to the Denon, the other speaker to the test unit.
Now with both amps on, you should get the exact same signal from both speakers. Mute one, then hit the mute buttons for both units at the same time to switch between the two. Match volume levels by ear if you don't have a meter (psychologically, louder sounds better even if the unit is actually worse).
You need to listen/compare at normal levels, then run things loud to make sure neither unit is too close to its limits. If your setup is in a smaller room, it would be good to relocate to a larger room for this test, so you can increase the volume without listening fatigue.
Especially on the vintage units, switch to the other channel to make sure both channels perform equally.
Early on and at least once you should swap the speaker cables at the amps - IMHO, it is far more likely that you will hear a difference between two "identical" speakers (or their room position even though they are close together) than any two competent amplifiers - unless you are pushing one of the amps beyond its abilities.
That said, we are emotional creatures! If one of the units looks really nice, has some controls you like (for example, I'm not convinced that a properly implemented loudness control is a mistake on an amp), or just "feels" better; and you have the money (and the upgrade "itch"), go for it!
Cheers,
Kurt
