So Denon and Klipsch are a bad combination...
JBong
Hi guys.
A few months ago I made a post for a new HT system. At the time I was thinking on getting an Axiom Audio 80-500-180 speaker system + a Yamaha RX-V3900 A/V receiver.
So far so good, except that I've postponed this plan until last week. Cruising audioholics' buying guides I changed the HT setup to a Klipsch RF-82 II speaker system (http://www.klipsch.com/eu-en/products/rf-82-ii-1-overview/) w/ a SW-311 sub (http://www.klipsch.com/eu-en/products/sw-311-overview/) + a Denon 4311ci A/V receiver.
After sending this setup to the importer of Denon and Klipsch (they're the same over here) for price, they came back and told me that this receiver wasn't the best one for the Klipsch speaker system I had chosen and proposed an Anthem MRX 700 (http://www.anthemav.com/products/anthem/a-v-receiver/mrx-500-2)
I had never heard of the Anthem brand (probably because I only know mainstream A/V receiver brands...) and now I have a couple of doubts...
1) Do you agree that Denon's receiver isn't the best for the Klipsch speaker system?
2) Between the 2 speakers systems (Axiom vs Klipsch) and the 2 receivers (Yamaha vs Denon), which ones would you pick for the final setup?
All your feedbacks are most welcomed!
JB
Hi guys.
JB
I would doubt the veracity of the importer's statement. I suspect there is the little matter of a greater profit involved.
Those Klipsch speakers state they are four ohm compatible, but you can go to the bank that they are actually four ohm.
Neither DENON or Anthem give their specs into four ohm. My hunch however is that the DENON has the more competent amps, but I have no way of knowing for sure. They certainly are the more powerful amps by a small margin.
I have not heard either of your speaker choices, so I won't comment.
JBong
Thanks for your reply TLS.
As far as I see the Audioholics 12k HT setup recommendation is to use a Marantz SR7005 receiver with this speaker set.
I'm totally lost here since I believed the Denon would be a better choice than the Marantz (even more since the recomendation for the 25k system is the Denon AVR-3808CI). What should I do? Can someone recommend me a proper setup within these price ranges? Am I good with the Denon 4311ci? If so, which would be the best 5.1 speaker setup to go along with that receiver for 4k-5k?
Thanks.
Thanks.
I can't help you further, as neither the receiver nor the speaker manufacturers are publishing full and adequate specs to guide us, which is a disgrace but common.
Ask the speaker manufacturers for at least an impedance plot and the receiver manufacturers to publish the amp specs into four ohm loads. Without that it is all hunch and guess work.
Klipsch for instance say the speaker is 8 ohm compatible, which is meaningless and worthless. The driver configuration however tells me the speaker has to be four ohm, at least in the region were most of the power is.
Seth=L
Seth=L
The Anthem has a toroidal transformer which reduces the weight and allows more effective use of power (efficiency). This is mostly a good thing. Anthem claims it is the most powerful receiver in its price field, I think this is far fetched. It is difficult to compare the two because they are very different. Even if they were more alike current limiting hardware can play a part in your real output performance. Without seeing the two receivers benchtested under the same conditions, one can merely speculate as to which is superior.
Anthem is owned by Paradigm of Canada. They are designed in Canada, built in China.
Whoever said Denon was a bad match for Klipsch either didn't like Klipsch speakers on anything but a tube amplifier, or is trying to upsell you to a product with a higher profit margin.
AVRat
AVRat
Where are you located in Europe? I’d skip the Klipsch sub and go for an SVS or Epik that can be purchased through this retailer: http://www.lsound.no/Map.aspx
The Denon 4311 is spec’ed for 4 ohm loads and will work just fine with the Klipsch 82s.
JBong
Thanks for your feedbacks guys!
A couple of doubts:
Which SVS or Epik subwoofer model would you pick? Any other recommendation on a good subwoofer for these speakers?
Do you think at this price range the Klipsch speakers are better than the ones from Axiom?
Thanks,
JB
GranteedEV
GranteedEV
Have you considered JTR speakers? Goonstopher on the classifieds is selling his mains and sub and they'd murk either the axioms or klipsches.
Between those two choices, i think the axioms will definitely sound a lot better but will be a lot more current hungry; the M80s are a true 4 ohm speaker with dips as low as 2 ohms - not many amps can truly feed them at high volumes. The klipsches will definitely get louder a lot easier. A few in that price range (new) I'd also look into would the Salk Song Series, RBH MC Theater series, and SVS' M series
For subs, I recommend ordering a pair of Rythmik FV15HPs
MidnightSensi2
JB
Denon is a quality product, I don't think it is bad for really any speaker versus another receiver in the same pricerange. Denon's amplifiers have always been staut.
As far as Klipsch versus Axiom. I agree with TLS that it is hard to determine much from the published specs Klipsch gives. Axiom is more helpful, but it looks like they have a trough into the 3-ohm range for the upper bass. Denons are generally pretty good to about 6-ohms at any decent volume level, in my experience. I'd say you'd need to run a 4-ohm nominal stable amplifier with those speakers, which puts you into the separates department.
I'd actually second the look at JTR speakers if you what big sound and to be able to drive them with just a receiver. I don't know the guy selling his online, but I do know Jeff at JTR is a great guy and worth giving a call.
I did some searching around for a friend recently and have had a hard time finding speakers that seem friendly with receivers and also sound okay. Interesting the disconnect of speaker companies to what most people use to power their speakers.
How loud do you intend to listen? Dynaudios DM 2/6's I've heard on a Denon 3808 (6-ohm) stable and they sounded great, but didn't have the dynamics of a JTR by any means. The Dynaudio's I'm talking about are a lot smaller, but I think they only cost about 700 bucks a pair if I remember correctly?
I've seen people looking at giant speakers though, and then later found out they don't like it "too loud" ... which made their initial concerns moot.
I have been over this ground before.
The problem is receivers period, especially at the price people want to pay.
We are in the era of narrow fronted cabinets, and so the speakers to be any good (not sound thin and puny) need diffraction compensation. For most speakers that means a boost of 12 db per octave starting around 600 Hz.
With a passive crossover the only way to do that is to drop the impedance so the speaker can draw more power, and a lot more power, as the frequency drops.
You won't get that kind of amplification at the price and space available in most receivers.
Class D amplification is an option, but those amps tend to perform poorly with passive crossovers. Those amps work much better as part of an active speaker system, like the Hypex modules.
So the options to make a load easy for a receiver are: -
1.) Return to wide fronted speakers. (poor imaging and multiple reflections spoiling the frequency response).
2.) If you pick a receiver use on or in walls, as they don't require diffraction compensation. Same problems as 1 above.
3). Use good external amplification and at the same time increase market share of pre/pros. They obviously ought to cost less than the equivalent receiver. For Marantz that is now so, and a step in the right direction.
4). Development of more numerous and affordable active speakers. This is by far the best solution to the problem. This should eventually lead to the phase out of the receiver which should happen sooner rather than later. Then the market will be entirely pre/pro and and cheaper than receivers. I also think active speakers could be highly competitive. A decent passive crossover is expensive, and the cheap components on most speakers severely limit their performance. Good active crossovers can be made cheaper than good and probably even poor passive ones. Class D modular amps can be made inexpensively and have a good track record when designed as a unit with a loudspeaker driver.
There are good reasons why I have never been a receiver fan boy. If people realized how much a receiver plus speakers with passive crossovers limit the performance of their systems, they would be demanding change within the industry.
As an aside anyone who puts speaker cable in a wall without putting it in conduit is asking for trouble. The day of change will surely come and those speaker cables will be useless.
GranteedEV
GranteedEV
Hrm?
Care to elaborate on why, for example, a hypex ucd400 module with plenty of power on tap would sound bad driving a passively crossed over speaker? I was considering making a two-channel amp for my e55ti's using those so you got my attention with that comment!
JBong
Just to update the current status: I'll be grabbing the Denon 4311ci for sure, just missing the final setup for the 5.1 speaker system...
@GranteedEV, any recommendation on the JTR speaker models to pick for the 5.1? Do you know if they ship to Europe?
@MidnightSensi2, since I live in a flat, I won't be playing them too loud. Still a move to a house with a dedicated HT room is in the plans for the next couple of years :)
So, can someone please elaborate on the models for both speakers and sub for around 3-3.5k USD/EUR taking in consideration the 4311 is guaranteed?
Thanks again!
One of the problems with class D amps is a problem of distortion changes with varying impedance. Class D amps as a group like a very flat impedance curves. The problems you get with class D are not lack of power with dropping impedance, although that can certainly be an issue, especially with the Sanyo chips, but change in performance specs with changing impedance, that usually is not owned up to in the specs, as it requires non traditional steps in evaluation.
It is a relatively simple task to stabilize the impedance of a solitary driver or pair, but once you add passive components things get a lot more tricky.
Even Hypex principally tout those modules for active designs.
There is a big highly technical article on the state of play of class D amps in the AES journal a got a couple of days ago. I'm just starting to scratch the surface of this highly technical article.
GranteedEV
GranteedEV
Thanks again!
Brand new, JTR speakers are a bit expensive and probably out of your price range - the Triple 8 for example is sold for 999, so three of those alone for a front stage would run your 3000. I suggested it earlier because it was a really great used deal on a pair of Quintuple 8s and a sub that you could add a triple 8 center (999 for one) and a pair of slanted 8s (1200 for a pair) to. I do bet JTR ships to Europe but it's out of your price range.
Anyways where in Europe do you live?
MidnightSensi2
This touches on how the perception and expectations of quality has really decreased over the past half century or so. From print, to television, to equipment, to....well, yeah...music. The problem with quality is that most people don't want to pay for it, and to develop it is expensive!
Bose is a bad word around here, but what Bose figured out that made them a brand was that people were more interested in tiny packaging and that they could take lots cuts in sound quality as long as it sounded (and looked) 'good' to a consumer. So, use some cheap drivers with fatiguing highs to have it sound 'clear' and bloat a bass 'module' to make some rumbling noise...and that's 'good' to people. That the bass is one noted and distorted makes no difference to most.
It's kind of like I buy cheap jeans rather than Armani. The Armani might seem like a 'rip off' to me, but really I look like a schmuck and the guy in Armani looks stylish, well-fitted, clean and pleasing to the eye. To me, they are 'jeans' and they work...to the guy into fashion its more than that...it's style, it's well-stitched, it's designed by very good designers, etc.
It seems like I'm getting off topic, but its really the answer to your question, I believe.
I think one reason why active speakers have stayed largely out of home theaters is also the requirement of having power cords to all the speakers. Speaker cables are pretty easy to tuck under carpet, fish through walls, and so forth, but installing power outlets is above most peoples desires, skillsets or budgets. Also, a lot of the moderately priced active speakers aren't really post crossover amplified, they are just regular speakers with plate amps.
Thanks again!
I'm sure JTR ships overseas, it's not really that difficult. Just figure out the duties on your end, if applicable. Remember, with the exchange rate you get a pretty good discount buying in dollars (I was just in Germany, I think it was 1.38E to 1USD or something).
The JTRs are probably way overkill for a flat, but if you plan on moving into a house in the next few years its not a bad idea to buy for that since your not really paying much more. I've always been a sort of 'buy in sections' type of guy. Like, if you got a 1.4HDMI receiver with pre-outs, you could always go the seperates route later on. And if you bought them amps, you can always upgrade your pre-pro. Speakers and amps last a long time (there are some advancements, but, really a good speakers now is like a good speaker from 10 years ago...*shrug*...and certainly amps are), receivers/processors date themselves quicker.
I'd go a little cheaper on the TV, since if you do a dedicated HT in your new house you're TV will either be in a bedroom or on eBay in exchange for a current projector.
Another thing you could do is buy some smaller nice speakers for your flat, and then use it in your bedroom of the new house when you move into the house and buy all new for your dedicated home theater.
In a nutshell: With audio/video gear, plan ahead and build piece by piece. Enjoy each bit as you get it and make it more of a process than an all out buying spree. If you look at most of the people with quality gear on here, it was acquired not by a giant budget but rather bits and pieces and lots of careful shopping and planning.
BMXTRIX
BMXTRIX
It hasn't been mentioned I don't believe, but the Denon AVR-4311CI is stable for speakers from 4ohms to 16ohms and it states this directly on the back of the receiver!
If you look at the photo in their product sheet which can be found here:
http://usa.denon.com/DocumentMaster/US/AVR-4311CI_Lit_913.pdf
The product page is here:
http://usa.denon.com/us/Product/Pages/Product-Detail.aspx?CatId=3d9614d1-8000-4106-ab91-8192242cab83&SubId=40b5820d-83c2-4e93-9909-60aae60e0bdd&ProductId=082714d9-ea72-4069-9b6b-a39c23290d98
Those specifications for the speakers are printed right on the back of the receiver.
Yeah, this receiver can definitely drive those speakers without a problem.
GranteedEV
GranteedEV
Trust me, it's not just about being stable to 4 ohms...the thing about the axioms that's always put me off is this:
http://emonatics.com/M80XPA-2.shtml
Maybe that's in a specific scenario running those speakers full range, but it's not something that I would entertain.
The issue is not the lack of a high pass filter, I have never seen that in a passive crossover, and I have never included one. The problem is that M80 is a flat out dumb design. It has two of everything for a start and a passive crossover at 160 Hz which is asking for trouble. If you need a crossover that low the speaker needs to be active period!
JBong
Guys, which JTR speakers would you pick for a 5.1 setup?
@GranteedEV: I live in Portugal.
@Midnight: The budget I mentioned is only for speakers. I'm thinking on a 55'' LED TV, but that's another talk :)
MidnightSensi2
I have three T8's well powered T8s for my fronts and in my little room the amps barely tickle the speakers and its so loud you'll think the bomb actually went off. I have the pro-version with the metal grills because I also use them in my DJ rig, but he sells them with cloth grills. I use Danley Sound Labs CS-30s for my subs, because I needed commercial output for use in my DJ rig but they had to be able to fit in my truck and also go low enough for dubstep music and home theater. So, my application is a little weird, double duty.
Here are some T8s: (old pic of my setup, I need to take some new ones)
http://forums.audioholics.com/forums/showthread.php?t=53920&page=10
Here are T12s (also old pic, rmk's, since updated with Orbit Shifter subs):
http://forums.audioholics.com/forums/showthread.php?t=36461&page=78
For the rears I'd go with Slanted 8's, I think that is plenty unless you have an extremely large room. RMK, for example, went with T8s for his rears, Slanted 8s for his heights, and T12s across the front.
Look at both of our home theater threads and notice how its a process though, both of us added little by little rather than buying all at once.
I think in your budget I'd try to get some T8s or make an offer on that Quintiple 8 setup in the classifieds, use whatever as rears while your in your flat and then buying some Slanted 8s as finances permit. Then when you move into your house, worry about the big sub(s). Maybe buy one now, then buy the second sub when you move into the house.
