The Sonus Faber Concertino speakers are said to be warm sounding. Try them out at Upscale Audio. The last I visited them, they were on sale for about P25T. Those Wharfedale evolution and diamond speakers have mid-range emphasis that can make them sound warm on some vocal materials, if not a bit forward. But they're below your price range. Those Monitor Audio speakers can sound similar to SF. But since you can audition any of them, I really would suggest you take the time to do so. Prefferably with the same amp that you have at home. Or you can bring it with you in those tests, if that isn't much of a hassle. Listening in Style at Shangri-la/Edsa and Architectural Audio can be very accomodating. So are the shops at Glorietta.
Just a bit of adivice. OFten the perception of warmth is a function of the room accoustics. A very live room, one with little or no sound absorptive materials like drapes, rugs and sofas, can make any speaker sound bright. On the other hand, a very plush and appointed room can make some speakers sound warmish, at least you get the sounds mostly from the speakers, with little or no mids and high frequency reflections reaching your ears.
Just curious, are your amps overly bright that you would want a warm sounding, albeit colored speakers?
