MichaelJHuman
I taped up the vents on my $100 Sony RX and hooked up 4 speakers in parallel to each channel and turned it up all the way.
It started smoking.
Is that normal?
mnnc
It started smoking.
Is that normal?
Let's see...I'm no genius but based on your descriptive behavior, yes. You don't have any pets do you?
Seth=L
Seth=L
Please tell me you filmed that.:D Because if you didn't film doing something so silly then what was the point, personal satisfaction in seeing a Sony product literally go up in smoke?
markw
It started smoking.
Is that normal?
This is a joke, right???
audiorookie
audiorookie
Yes its normal for it to smoke if you tape up the vents.
pouring lighter fluid into the receiver will give you a better light show.:eek:
bandit
I'm wondering.... what would happen if you removed the coolant from your cars radiator???? Perhaps you'd get better milaege without having to carry the weight of the coolant around....
:eek:
Voodoo Child! :D Last time someone asked me what to do with their old Sony receiver, that was my recommendation :D
highfihoney
highfihoney
What you just witnessed was the magic smoke,if you try sticking a butter knife in the back of your tv set you'll see something wonderfull.
evilkat
evilkat
I think a better idea would be to remove the cover and touch the big cylindrical thingies that are otherwise known as capacitors. With your tounge.
Seth=L
Seth=L
I know how you can fix the Sony, put it in the microwave and set the timer for 2 minutes. Don't mind the sparking, this is normal.
Also, take apart a tube tv, if you have one, and disconnect the little rubber thinger on the tube, there should be a wire there, touch it, but be certain that you are grounded.
markw
Another fun trick...
Remove the back of a big screen CRT based TV set and, for a truly mind-blowing experience, lick the picture tube.
(kids, don't try this at home. We're trained professionals.)
stratman
stratman
THESE ARE THE BEST POSTS I'VE SEEN IN A WHILE!!!!!!!!!!!!!!:D :D :D :D :D
Someone tell this guy he's got to film this and post!!:eek:
mnnc
Oh yes...I almost forgot. When playing with electronics you must always ground yourself in ankle deep water.
Seth=L
Seth=L
So that's why that TV repair shop has buckets of water.
I said something like that earlier, and that would be great. Kind of like the miraculous exploding computer on google videos.
mnnc
In HiDef of course! :D
mnnc
That water is used to put them out when they catch on fire :eek:
stratman
stratman
Or just throw your big ol' rear projector in the pool and go in for a swim.:)
Seth=L
Seth=L
Don't forget to plug it in, and check the breakers to be sure they are on for your viewing experiance.
