I don't understand those graphs :\ Care to offer a simple explanation?
Can the EP2500 run one of these subwoofers with just one channel? Do I have to run it bridged?
My idea was to power the sub with channel 1 and use channel 2 for tactile transducers.
The basic issue was that some people thought the port resonance of such a design would be audible as it is far lower than typically found in commercial and DIY designs. To prove that the port resonance would not be audible I took 4 measurements of the subwoofer alone:
Maroon is the subwoofer measured from 1" with no crossover.
Blue is the subwoofer measured from 1" with a 4th order Linkwitz-Riley crossover at 80Hz.
Purple is the port measured from 1" from the opening with no crossover.
Green is the port measured from 1" from the opening with a 4th order Linkwitz-Riley crossover at 80Hz.
Note the peak in both port measurements at about 111Hz. This peak is the port resonance.
The conclusion of these measurements is that audibility of this peak when attenuated by a 4th order Linkwitz-Riley crossover at 80Hz is nonexistent as correlated with credible perceptual research and my own experience. Thusly, there is no need to worry about coloration due to port resonance in such a design.
