Should I worry much about humidity?
TaroTaro
I usually like to open my windows/patio door in my living room where my speakers are located. I'm wondering if I should be aware of my humidity inside, as I don't want to damage my speakers.
I live in a more humid part of the country, for example, this morning my living room is at 61% humidity (it was raining yesterday, and I have the windows open for fresh air). Should I be worried at all about my speakers? Or no big deal?
BoredSysAdmin
BoredSysAdmin
not for speakers, they tend to get damaged more likely in a too dry environment, that said I'd be worried about above 60% humidity for possible mold growth if you have low air circulation.
Pogre
Pogre
Too dry? I live in the desert so it's about as dry as it gets out here. What about too dry does one keep an eye out for? I'm not being facetious, I haven't owned anything that's in service long enough for wear n tear to be factor yet, but plan to keep my current speakers for a long, long time and hadn't heard the dryness thing before.
I could see maybe some materials used for surrounds drying out and cracking I s'pose. Mine are all rubber 'cept my HSUs. I'm not sure what HSU uses for their surrounds but I know it's a compound, not pure foam.
shadyJ
Speaker of the House
Staff member
Hsu uses butyl-rubber foam. It's lighter than rubber but much more durable and much longer-lasting than foam.
I think you need to be much more worried about your electronics than your speakers. A lot of components and circuit boards do not like high humidity.
Up here in the upper Midwest we have historically been on the dry side. Not any more. Once the weather warms up we have far more very humid days than dry ones. To my way of thinking this is the most obvious and recognizable consequence of global warming. This is not healthy. So I think a lot of homes now need a central dehumidifier as part of their HVAC system. This makes the house much more comfortable in the warmer months. The more your house is insulated, the more essential this becomes. The reason is that your AC will run less, and so not as much water vapor is removed. Then you get that nasty cold clammy condition, which is uncomfortable and not healthy.
In addition the dehumidifier off loads your AC by alleviating a good deal of the burden of latent heat energy required to condense water vapor, back to water. It makes your whole AC system much more comfortable and efficient.
This is now an item that most homes require. It is easily added to any HVAC system. Set your house humidity to 42% and you will be amazed how much more comfortable your house becomes. It will be a lot healthier for you and your electronics.
Teetertotter?
Teetertotter?
I wouldn't worry about it and keep the air circulating, if you don't have AC. FANS Some keep the furnace fan running year round. Heat might be more of a concern?
