Should I turn off power to my receiver or leave it on standby (Yamaha RX-V675)
Verdinut
Verdinut
The only way I can completely turn off my Yamaha receiver is to unplug it. I have no problem leaving it on standby but it is in an enclosed cabinet and only gets ventalation when I open the front door to use it. Does not get real hot but warm. Am I doing any damage to the reciever? Thanks
Would it be possible for you to install a small cooling fan on the back of the cabinet to keep it cooler, such as one of these:
L
Lotus123
What temperature is it getting up to in there? It's easy enough to add some external cooling....
I checked the temp and it is only 80 degrees so I guess I don't have a problem. Thanks for the idea that I should have thought of myself. Terry
Is that the heat generally in the whole cabinet or are you measuring the case of the avr? Will this change during summer?
Speedskater
Speedskater
Most modern components use very little power in the stand-by mode. A 'Kill-a-Watt' power meter can give you a few hours of fun measuring things. Note that some TV Set-Top-Boxes may not show much difference.
No reason to power-down completely unless it will go unused for several days.
L
Lotus123
I measured it on the avr and on the cabinet shelf and it was the same. Since we use A/C, I don't think it will be any higher in the summer.
