Clint,
> I bet it sells lots of acoustical panels ... you do a good job of self promoting yourself for free <
I visit this forum and others to explain room acoustic problems and solutions, and for no other reason. There is a lot of misinformation floating around the web that needs correcting, and my only goal is to help. I often refer people to my
Acoustics FAQ, which shows how to build your own treatment. This is hardly what you'd expect from someone in the business of selling acoustic products. But I believe
so strongly in the importance of acoustic treatment that I'd rather help people build their own than have them go without.
That said, let's discuss the issues:
> avoid misleading our readers by ignoring the benefits of proper room EQ systems and over-accentuating the importance of passive-only solutions. <
I have already explained in great detail the many limitations of active room correction. Of the many points I made in that other thread, which do you not understand?
> when dealing with actual furnished rooms, smaller is far easier to tame. <
That simply is not true. One big reason small rooms have worse low frequency problems than larger rooms is because in a small room you are always near to a boundary. Aside from modes, which are also less of a problem in large rooms, comb filtering always exists near a room boundary. In a small room you simply can't get far enough from any boundary to avoid this, so the peaks are larger and the nulls deeper than in a larger room.
If you have an explanation for why you believe otherwise, I'd love to hear it. That is, don't just say I'm wrong, but explain
why you think I'm wrong.
Thanks.
--Ethan
