I find it odd that nobody considered the possibility that a typical wall cavity IS the space used for the design. That occurred to me yesterday and as I had mentioned, Focal can be contacted for info, and I did that before I even posted. They won't give me the parameters, but wrote that the typical cavity with 2x4 framing, 14" o.c. and 96" high is the volume they use. The fact that the internal height is 93-1/2" shouldn't matter much.
"Regarding placing the 1000 ICA-6 into an enclosure we would recommend that these be placed into a larger sealed enclosure. These speakers have been designed and engineered to be installed into an infinite baffle application and when placed into a smaller enclosure, can impact the lower frequency output. As an example, the 1000 ICW-6 is the same speaker, just without the angle option and can reside within a standard 2x4 wall cavity. this on average measures 3.5" x 14"x 96" equaling 2.72 cubic feet for optimum performance. As mentioned above, these can be placed in smaller enclosures but will affect the low-end frequencies. The smallest enclosure that we would recommend would be 1.25 cubic feet.".
