Hello,
I have a P-965 which is almost working.
At first, both control knobs (Multi-Control / Volume) weren't responding correctly, so I cleaned the rotaty encoders, and they now work as new.
However, the volume stays to the maximum level even though I the output level changes on the screen and varies within -70dB and +20dB.
I would like to know if this is a known issue and what could be the cause. I'm using the analot Aux Output.
Also, is it possible to check the actual firmware version ? Where can I find the latest version as well as the utility for flashing, considering that this preamplifier is 20+ years old ?
Last: I see one DB9 serial port and one USB port above the optical inputs. Can the USB be used or do I need a DB9-to-USB adaptor ?
Thanks.
