I am re-posting this question in this forum as i thought this forum topic was more appropriate .
I currently have Infinity Beta 50s(20-250w)and matching Center Beta 360 and Polk Audio F/Xi A6Bipole/Dipole sides and am replacing my rears with two more Infinity Beta 50s for the rears. to match fronts
I have connected my new(used) ONKYO TX-NR808 135wx7, FR, FL & Center preouts to My (previous)Sony STRG800’s 110w x7, Multi Channel inputs and used the button on the front “
Multi Channel "
Direct" button. And I now have the 2nd amp/receiver(sony) powering the three fronts and the onkyo powering the surrounds the new 50s and providing all sounds to speakers through
(straight through just amplification)(no distortion). And also have all speaker volume control with the main volume control on ONKYO. (i have my sony on a preset volume)(then calibrated all levels accordingly and set). sounds great ..Depth and Sound stage are finally full and sound great..for me. And all that I have to do is power up the two units on start up. But i think i can power up both at same time using remote programming options. i have three active subs which connect to onkyo
I have an oppertunity to purchase a
SHERWOOD NEWCASTLE 7CH POWER AMPLIFIER $500-600.
i am trying to see the benefit of trading out the Sony and using the Onkyo just as a pre-amp and having the sherwood drive all 7 speakers, there are some small conveniences like 12v auto on etc. but are there some advantages or differences in sound that or amplification methods that i am not seeing/ I see that it is like 12 inches tall , and I would have to shift some things around quite a bit to accommodate and provide adequate ventilation that is a set up disadvantage. The pros would have to outweigh the cons is what im getting at.
the 500 bucks is also a consideration(alot for me) ..Thanks
Here are some speaker specs so you could see them.
Specifications:
SHERWOOD SPECS
1050 Watt 7 Channel Main Amplifier
- Designed for Low Impedance Loads
- All-Channels-Driven Power 20 Hz-20kHz 100 Watts per channel (x 7) into 8 ohms 160 Watts per channel (x 7) into 4 ohms
- THD <0.02% from 20 Hz-20 kHz, 8 ohms
- THD <0.09% from 20 Hz-20 kHz, 4 ohms
- 2 Toroidal Power Transformers
- 7 Separate Discrete Amplifier Modules Built as 7 Separate Monoblock Amplifiers
- Totally Discrete Amplifier Stage for All Channels
- Gold Plated Inputs
- Heavy-Duty Speaker Binding Posts compatible with bare wire, banana plugs and spade lugs
- Remote turn-on via 12-Volt external input
- Aluminum Front Panel
Infinity C360 Center (current)
● Drivers: One 1" Tweeter, One 4" Midrange, Two 6.5"
Woofers
● MFR: 45 Hz - 20 kHz ± 3 dB
● Nominal Impedance: 8 Ohms
● Sensitivity: 91 dB @ 2.83v @ 1 m
● Recommended Power: 10 - 200 Watts
● Dimensions: 8.5" H x 25.6" W x 11.75" D
● Weight: 34.5 Pounds
infinity Beta 50
Tower (current)
(buy two more and have four matched)
● Drivers: One 1" Tweeter, One 5" Midrange, Two 8"
Woofers
● MFR: 35 Hz - 20 kHz ± 3 dB
● Recommended Power: 10 - 250 Watts
● Dimensions: 41.3" H x 10.4" W x 14.8" D
● Weight: 62.5 Pounds/Each
