Shallow Depth Receiver
Brento
Can anyone please advise me on a decent receiver with a depth of no more than 10inchs / 25.5 cm. Thanks , Brento:
Snap
Snap
hate to say this but I think you are out of luck. None of the stuff that I know about is that depth. Plus do not forget that even if you use 90 degree RCA connectors you are looking at another inch on the back side.
Any way that you can go deeper????
rschleicher
At only 10 inches or so I think you are probably SOL.
If the issue is fitting the unit into an existing piece of furniture, you are probably going to have to get out a saber saw or jig saw and cut a cut-out on the back of the furniture piece, to have your receiver stick out the back. Or else get a different piece of furniture (or a rack).
jcPanny
jcPanny
Receiver ventalation
Even if you found a 9 or 10" deep receiver, they require proper ventelation to operate properly. The standard size for most AV components is about 18" deep.
